Une version éléctrique de la Golf 1 cabriolet a existé. Cette adaptation non officielle a été possible grâce à un kit distribué par Electro Automotive. De nombreux anciens modèles de véhicules pouvaient être adaptés en version électrique.
Annonce de vente d’un modèle éléctrique :
Selling a truly unique classic car! Converted to all electric with a professional Electric Vehicle (EV) kit, never need to fill up with gas! The drive experience is just as unique being virtually silent! Do the math, one charge for 30 miles will set you back around $1 in electricity! Plug in the electric cord where the gas used to go in the car. Charge time is roughly 7 hrs for a dead battery.
Did I mention you can pre-heat or cool the car while it’s plugged in? And that you can use the car’s batteries as a huge battery backup to run small/medium appliances when your house looses power? Street legal, goes highway speeds and it is insured with clean title.
Perfect for anyone desiring a short distance commuter, weekend toy, or neighborhood electric vehicle (NEV). The best part is you charge it with a regular electric outlet! You’ll get a little over 30 miles per charge, 25 miles for good measure. If you commute, you may be able to charge at work, doubling your range per day!
The bones of this electric car are in great condition. Body, paint, top, transmission are spectacular for a 1985 VW. Has a meager 85,000 miles, and was converted all electric about three years ago using the well-designed and popular ElectroAutomotive Volkswagen Rabbit kit (aptly named the VoltsRabbit kit). Google the company and kit and you will see the comprehensive list of integrated parts and support that are installed and fully functional on this car. This VW has the 108V premium option for added range and performance. Total conversion cost of the kit without labor is currently retailing for over $12,000. Include the low mileage car, healthy batteries, and optional converted heating/air conditioning system, the total cost exceeds $20,000.
There are many reasons you may want to step up to electric, the pure efficiency to support our environment (approx 90mpge), the less maintenance required (no oil changes, radiator, fuel system, engine tune ups, exhaust, etc.), vacation trailer queen, or for the pure hobbyist.
The car comes with:
– Fully integrated and functional 1985 Volkswagen Cabriolet Convertible with the 108V VoltsRabbit kit.
– Healthy batteries showing full charge.
– Fully functional heat and air conditioning.
– Alpine CDE-123 Stereo with USB, AUX, Bluetooth/Pandora, and handsfree mic installed.
– Premium extension cord to charge on a regular house outlet.
– ElectroAutomotive Conversion Kit Installation Manual, Operations Manual, and Wiring Diagrams
– OEM VW Owner’s Manual
– Battery maintenance tools (only routine maintenance, just top-off distilled water to the golf cart batteries every 4 months)
– Clean Title in hand
I’ll give test drives, but be sure you’re a serious cash buyer, please.
À vendre : une voiture classique vraiment unique !
Entièrement convertie à l’électricité grâce à un kit professionnel pour véhicules électriques (EV), vous n’aurez plus jamais besoin de faire le plein d’essence ! L’expérience de conduite est tout aussi unique, presque silencieuse !
Faites le calcul : une recharge complète pour environ 50 km (30 miles) vous coûtera à peine 1 $ d’électricité ! Il suffit de brancher le câble à l’endroit où se trouvait l’orifice du réservoir d’essence. Le temps de charge complet, batterie vide, est d’environ 7 heures.
Saviez-vous que vous pouvez préchauffer ou refroidir la voiture pendant qu’elle est branchée ? Et même utiliser les batteries du véhicule comme une réserve d’énergie pour alimenter de petits ou moyens appareils électriques en cas de coupure de courant !
Homologuée pour la route, elle atteint les vitesses d’autoroute et dispose d’un titre clair ainsi que d’une assurance valide.
Idéale pour ceux qui recherchent un véhicule électrique de proximité, une voiture de week-end ou un petit véhicule de quartier (NEV). Le meilleur : elle se recharge sur une simple prise domestique ! L’autonomie est d’un peu plus de 50 km par charge (comptez environ 40 km pour être prudent). Si vous allez au travail avec, il est même possible de recharger sur place, doublant ainsi votre autonomie quotidienne.
La base de cette voiture électrique est en excellent état. Carrosserie, peinture, capote et transmission sont spectaculaires pour une Volkswagen de 1985. Elle affiche seulement 85 000 miles (≈ 137 000 km) et a été convertie à l’électrique il y a environ trois ans à l’aide du célèbre kit ElectroAutomotive Volkswagen Rabbit, surnommé VoltsRabbit.
Recherchez ce kit sur Google et vous verrez la liste complète des composants intégrés et du support technique : tout est installé et pleinement fonctionnel sur cette voiture. Ce modèle dispose de l’option 108 V premium, offrant plus d’autonomie et de meilleures performances. À elle seule, la conversion (hors main-d’œuvre) coûte actuellement plus de 12 000 $. En incluant la voiture à faible kilométrage, les batteries en bon état et le chauffage/climatisation convertis, la valeur totale dépasse 20 000 $.
Passer à l’électrique présente de nombreux avantages : efficacité énergétique (env. 90 mpge), respect de l’environnement, entretien réduit (pas de vidanges, radiateur, système d’alimentation, réglages moteur, échappement, etc.), ou encore projet idéal pour les passionnés ou collectionneurs.
La voiture comprend :
– Volkswagen Cabriolet 1985 entièrement opérationnelle avec kit 108V VoltsRabbit
– Batteries en bon état, tenant bien la charge
– Chauffage et climatisation entièrement fonctionnels
– Autoradio Alpine CDE‑123 avec USB, AUX, Bluetooth/Pandora et micro mains libres intégré
– Câble d’alimentation premium pour recharge sur prise domestique
– Manuels d’installation, d’utilisation et schémas du kit ElectroAutomotive
– Manuel d’origine Volkswagen
– Outils d’entretien des batteries (simple appoint d’eau distillée tous les 4 mois pour les batteries de type « golf cart »)
– Carte grise propre et disponible
Essais possibles uniquement pour acheteurs sérieux et disposant des fonds nécessaires.
