J’ai un petit souci de température de flotte
lauraturner6223
Prénom : laura
Année : 1981
Version : Bel Air (bi-ton)
Message par lauraturner6223 »
Shark Navigator Lift-away Nv360 Vs Nv352 Vs Nv356e Vacuum Cleaner
Shark NV360, NV352 and NV356e vacuum cleaners are all good quality vacuum cleaners and have been favored by many consumers for nearly 10 years. Today, let's do a comparison between the three machines and try to find out which one is the best. The end result is very surprising.
The similarities
Based on the looks, all three Shark Navigator Lift-away NV360, NV352 and NV356e Vacuum Cleaner share the same general structure. The basic construction, for example, is a 2-in-1 design, meaning you can detach the vacuum cleaners from their own parts and turn them from a handheld vacuum cleaner into three machines with separate canisters for handling and easier cleaning job. And because of that amazing design, all the narrow and difficult places to reach in the house such as interior surfaces, stairs, curtains, ceilings … will be handled with just one button.
They also have the same 1200 watt vacuum cleaner, same brushed floor nozzle design which have the same width. They also have the same scroll brush change mechanism below the nozzle. Just press the on-off switch above the handle, you can turn the brush up to vacuum hardwood floors to avoid scratching the floor, and turn it back on when working on the carpet for a good carpet cleaning.
They also have a very guaranteed 5-year warranty. More importantly, they also have the same anti allergen complete seal technology with HEPA filter, which helps keep and remove 99.9% of dirt and human allergens, one thing that no other vacuum cleaners in the same price segment are equipped with.
Visit This Site: Shark Navigator Lift-Away Deluxe NV360
The differences
Noticeable specifications:
  • Pricing: The blue shark vacuum deluxe NV360 has the lowest price and the NV356e has the highest.
  • Dust box capacity: The NV360 and NV352 have the same 1.32 liter dust cup. Meanwhile, the dust box of the NV356e is larger with a capacity of 2.42 liters.
  • Power cord length: NV360 and NV352 have equal wire length of 25 feet and NV356e has up to 30 feet of power cord.
  • Weight: The NV360 is 13 lbs, NV352 is 12.5 lbs and NV356e is 13.7 lbs. And you also need to know that these 3 machines are lower weight than the vacuum cleaner in the same price segment. That is why consumers like them so much.
Power and performance:
All the three machines have great performance on cleaning dust and debris on the floor and carpets. Actually, they do a better job than all the vacuums in this price range. The NV352 consistently scored higher than the other two with both suction power and airflow on areas such as floor, carpet, stair, sofa and outside places. And the NV356e is consistently getting the lowest score.
About the working noise, the NV352 is showing the most power and also showed itself to be the loudest.
Conclusion
So based on all the factors above, I would recommend any of these three vacuums without hesitation as I think that the navigator lift-away vacuum cleaner series is the best all around vacuum. In the budget category, I would say that the classic version, the blue shark navigator nv360 upright vacuum deluxe NV360 lift-away is the best option for those who want to have a powerful suction machine, and a less noisy one also. Though NV360 has a slightly less strength than the NV352, it is still an ideal vacuum cleaner with powerful suction, good performance and absolutely convenient to bring around.
Modifié en dernier par lauraturner6223 le mer. janv. 10, 2024 09:11 am, modifié 4 fois.
Re: J’ai un petit souci de température de flotte
Ton garagiste n'a pas fait un tour avec la voiture pour tester le dépannage ?
Bonjour Laura et :bienvenue sur One Cab.
si il monte a fond c'est peu etre un probleme de niveau d'eau dans le bocal ou de sonde de bocal....le système de sonde déclenche la monté de l'aiguille et clignotement du voyant en cas de manque de liquide de refroidissement (ou défaut de sonde) ;)
kapowa
Prénom : Capitaine_Calamar
Lien vers la présentation : viewtopic.php?f=2&t=30479
Message par kapowa »
A ce propos, vu que je viens de faire réparer mon mano du compteur, jusqu'à ou peut monter l'aiguille?
Quand il fait bien chaud, j'ai vu que ça monte au 3/4, mes ventilo se déclenchent bien, le voyant d'ailleurs ne s'allume pas mais ça surprend un peu. Bon, je sais que l'on est pas dans une voiture moderne avec une aiguille droite fixe au bout de deux minutes de trajet.
Normalement elle s’arrête au milieu et peu dépasser quelque fois, mais après ça dépend aussi ou tu acheter sa sonde d'eau car souvent celle vendue en repro sont pas très précise ;)
kapowa
j'ai remis ma sonde d'origine quand j'ai supprimé mon mano sur le bas du tableau de bord
Il faudrait essayer avec une sonde neuve ;)
